if the grounds "look" good, why not be sure they "are" good? try a different spot. it's not the amp if this happened with another amp. check your grounds. also is the fuse big enough?
Ill try moving the ground. What do you mean ground isolation tho?
Ive had this ground for a year I dont understand how it would just start causing problems, and how a bad ground would cause the fuse on the amp to blow.
Chances are this amp was damaged when the other amp went and it is just now reached the non-working point. Something is probably wrong internally when the event that ocurred the first time that took out the other amp.
As was said, you probably have issues with the amp. Disconnect all speaker leads and power it up. If it still blows the fuse the amp is most likely dead.
