recommend me an amp for...
hmm.... could be bad amp. how are they wired to the amp? did you observe correct ohm wiring? is the amp going into protect? check your grounds (thats my answer for all amp probs...)
the subs are wired for 4 ohm and its a 2 ohm stable amp. i dont think its going into protect cause the green led just turns off when the stop hitting. the ground for the amp is wired to my engine block so i dont think its a bad ground.
the amp has been around the block a few more times then it should have. i got it from a friend who got it from a friend who got it from another person. im sure it goes farther than that but thats all i know.
i thought i knew what was good and what wasnt before i came here and seen everything everyone else had. i was looking into jbl/ the crown amps but im sure theres somthing a little cheaper.
ExpiredDrummer
ExpiredDrummer
livonia michigan
jco1385
