ampo turn off noise?
yea i kno what ur talkin about ive heard that sound before, ive heard that it has somethin to do with the current and the woofers bein cut off and it doesnt hurt the subs, but i could be wrong im not so sure
I think that the a turn OFF thump coming from subs is an indicator of an insufficient ground. I assume you already have decent power and ground wires for your amp but did you upgrade the the batterys negative terminal grounds?, thats usually where the bottleneck occurs. The wire going from the - terminal to the fender and the ground strap on the engine are the only ways for the amp ground to get back the battery unless you have run the ground cable directly to the negative terminal on the battery.
Just quoting from FAQs ive read, I would just get a different amp personnally.
Wouldnt it be better to try to get rid of the problem than to get a different amp?
Theres several threads about on/off thump, search for them.
'Cuts and pastes'
2.2 My system "pops" when I turn it off. What is happening and how
can I get rid of it? [JD]
This kind of problem is often caused by transients in the signal
processor as it powers down finding their way into the signal path,
which the amplifier then transmits to the speakers.
Usually this can be solved by adding a little turn-off delay to the
processor. This allows the processor to stay powered on for a short
time after the amplifiers have powered down, thus preventing the pop.
Many components sold today (such as crossovers, equalizers, etc) have
delays built-in. Read your manual to see if it is possible to set this
delay on your piece of equipment or be sure to look for this feature
during your next car audio purchase.
If your processor does not have this feature, you can build your own
delay circuit with a diode and a capacitor. Add a 1N4004 diode in
series with the processor's turn-on lead, striped side towards the EQ.
Then add a capacitor in parallel, the (+) side of the cap connects to
the striped (processor) side of the diode, the (-) side of the cap goes
to ground (not the radio or EQ chassis - connect to the car chassis).
Experimenting with the cap value will give you the right amount of delay
before the EQ shuts off. You don't want it too long, just long enough to
make sure the amp is off before the EQ powers down. 220 - 1000 uF is
about right, and make sure the cap is a polarized electrolytic, 16V or
higher. Also keep in mind that the diode will introduce a 0.7V drop on
the remote wire, which can cause the processor to power down before the
rest of the system.
hmmm, i actaully did search and that was the only one i came up with also^^^.
and yea, i have changed all the wire under the hood,
I mean its funny because for instance, i didn't have alt whine right, take the amp out, put it back in and it whines. some funny wiring going on in my car i guess.
djjdnap
FreakyFreaks ofall Freaks
djjdnap
indy-nap-lis
djjdnap
