AmplifierLink + CDA-9835??
tgenius
For those of you that have these hooked up to an Alpine amp, how do you change the settings on the HU of the amp? I can only see voltage/amps/temp right now by hittling the display button a few times. Any help would be greatly appreciated as I can't find it in any manual!
Heres what you do. If you hit menu and go to aplifier link you can select your two presets on the amp, 1 or 2. If you hold down menu and go into your crossover, eq, time correction, etc, menu and go to amplifier link you can change your bass and amp settings. I can change my bass setting from 0 to 11 for the amp but for some reason it won't let me do the other settings. I have the two settings on my amp set for different types of music so I can change the amp presets quickly.
Bill3508
Bill..can you please post your sub values for me so I can program them in? Also, would you mind sending me your Crossover values that you programmed with iPersonalize (if you did)??
Which amp do you have, mine is the MRD-M301, running a JL 10W3 at 2 ohms. My amp settings are input switch to 4 volt, input 0, gain 0, bass boost off, Low pass set at 80/24( used the amps lowpass instead of headunit sounded better that way). Subsonic filter off(sealed box for me), Eq off, and make sure you save your settings with the last menu item (memo). YOu can name amp 1 with preset of 1 or 2.
My headunit crossover for front and reat are at 100/12, and the subwoofer I have set to 80 flat, this way it won't interfere with the amp low pass. Now to get the best benefit out of this amp and this headunit I had to make it where my normal listening level on the headunit is 23-26. The front and rear preouts seem to be much stronger than the subout(been told that the subout only produces the 4v with the hu sub volume set to 15.) With these settings I get great out put and have my hu sub volume set to 8 or 9. I can run the headunit to 35 with no clipping or distortion, but normally max for me seems to be 30.
You will have to try and see how these setting work for you and compensate.
Bill3508
Bill-did you use iPersonalize to set these values? When I set 100hz should it be 0 or -12, in both cases, it says out of range? Any help would be greatly appreciated.
tgenius
tgenius
Miami, FL
Bill3508
