amplifier
  • 3
fredmny
ok guys i am kinda new at this but not. i've hooked up car systems before but don't know all the technical things t ogo with it, i want to know which is better, rockford or kicker? i want to get 3 L7's i need to know what amp should i run. i know i will need probably two amps to puch them. should i stay with kicker amp or should i go elsewhere for a good amp to push those bad boys. also if i need more than one amp to push them i need to know how do i hook up all three amps. thanks guys
To me rockford and kicker are on about the same level. What size L7's are you looking at ? You don't have to use a kicker amp. You can if you want. But you can find comprable amps for alot less money. Such as the jbl 1200.1 1ohm stable and puts out 1200w x 1. US amps also makes some decent amps. That are alot cheaper than kicker. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
RF amps are alot cheaper than kickers amps in my opinion like almost everythig kicker makes but 1 1200.1 jbl and a 600.1 would do awsome and the 1200 in like 260 on ebay and the 600 is like 180 on eaby.
The CT's are nice, That Sundown is a a frik'n beast!
7
566
605
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
9
617
fredmny
fredmny
madison illinois
jlman
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
