Amplifier Selection...
Justin Thibert
Since I know little about car stereo enhancments.... Can someone direct me in the direction of a good amp... One that will power four 50 watt speakers and then one the will power two 10" inch subs....
I was looking at a
Kenwood 180W x 4 Class AB Bridgeable 4-Channel Amplifier with Variable Crossovers
200W peak output x 2 @ 4 ohms, bridged
180W x 4 peak output @ 2 ohms
110W x 4 peak output @ 4 ohms
100W RMS (continuous) x 2, bridged
55W RMS (continuous) x 4 @ 4 ohms
90W RMS (continuous) x 4 @ 2 ohms
2-, 3- or 4-channel output
High-pass/low-pass selectable crossover; bass boost
Cast-aluminum heat sink with aluminum dress plate
Toroidal noise-suppression filter
Gold-plated terminals
But the one for more subs is questionable and I dont know wheter to get a mono amp or a 2channel... I know that a 2 channel would be cheaper but I just dont know!!
Any knowledge of certain products would be very very very appreciated..!!
Thats more than enough.
You can buy two amps for that amount.
I would buy a cheap amp for the interior, some 4channel amp
then for the subs, depending on how much they will take rms would depend on how much i would spend on that amp
how are audiobahn amps...? Because I was think of getting an audiobahn 4 channel for my 2 10" subs... But for my 4 speakers should I get a cheaper 4 channel or should I just stick with the same one....
//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif no AUDIOGONE I mean AUDIOBAHN.......
brand new in box with full kicker warranty - this will be plenty for your "50 watt speakers" and your "two 10 inch subs";http://www.thezeb.com/p-Kicker-KX-Series-KX700.5-106378.htm
mind posting what speakers they are and what subs they are? wanna be sure they can take this power, and that they arent complete garbage. the amp above, is quite high quality, and right in the middle of your budget.
Can you see how this will work with it?
http://www.dealtime.com/xPF-Rockford_Fosgate_Rockford_Fosgate_Punch_Stage_2_10_4_ohm_Component_Subwoofer_10_Component_Subwoofers
Thats for my subs... good or no becuase I have not ordered them yet!!
Justin Thibert
Justin Thibert
San Marcos, TX
Justin Thibert
NorthFramingham
    Jun 30, 2026
