Shit, I saw this on my user CP but had no time to respond, before I knew it it fell off the CP and I forgot. Thanks for the bump.
Defiitely get a few extra; also see if
PartsExpress has them; they might be cheaper there.
As far as soldering goes, I hope you're well equipped.
This is how my repair went:
1. Use cutting pliers to snip off as much of the mosfet as possible
2. Use gripping pliers to grab the existing mosfet's pins on the top of the board
3. Use soldering iron to heat the solder on the underside of the board as you pull up on the pin.
4. Use solder sucker to **** solder out of holes while you hold the soldering iron in the hole from the other side.
Now you have empty holes that your mosfets will fit comfortably into.
5. Drop mosfets into the holes and bend them at a 90 degree angle to replicate how the old ones sat in the board before you clipped them.
6. Use soldering iron and the Flux solder available at RadioShack to solder the bottom tips to the board. Usually as you do this a little bit of solder will seep through the board and give you quite a thorough connection; however it won't seep through the board too much because it dries almost instantly.
7. Some mosfets have resistors right next to them, and one of the pins is connected to that resistor. Before you clip your resistors, examine carefully if your mosfet is supposed to be attached to that near resistor.
8. Now that you have all your soldering points soldered, first make sure to break the connection in the solder as much as you can with the soldering gun and a solder scraper (or small flathead screwdriver). Be sure not to damage the board, and make sure you leave the connection where it needs to stay, such as those mentioned in step 7.
9. Clip off as much of the mosfet's pins as you need to on the bottom so the board will sit comfortably in the case.
10. Apply a few layers of electrical tape if the pins of the mosfets could come in contact with the board case under the board.
Any questions?
Brian
