Amplifier Recommendation
Normally, anything with the word pyramid, or legacy aren't very good... Sure you can buy it now, but you'll be buying something else in a month to replace it....
Are you saying it because it doesnt give u a lot of power ? because if is that i dont want a lot of power as long as i feel that is doin around 500watts im ok with it . Or are you sayin it because it doesnt last ?
no its just because pyle, legacy, pyramid are all not quality brands...sure u can get them for cheap but like he said above you'll be paying to replace them real quick...
This is its actual 14.4 volt power output.
Pyramid 712X
75 watts RMSx2 @4ohms
150 watts RMS x1 @4ohms bridged.
Is 150 watts RMS enough for your needs?, cause thats all your gonna get from this amp.
If you want a cheap *** budget amp that will work, the Pryamid PB2400D will work well for subwoofers.
Rated at
1 x 800W RMS at 4 Ohms
1 x 1600W RMS at 2 Ohms
1 x 2400W RMS at 1.3
Actual power output
1 x 400 RMS at 4ohms
1 x 700 RMS at 2ohms
1 x 1000 RMS at 1.3 ohms
If you want a cheap *** budget amp that will work, the Pryamid PB2400D will work well for subwoofers.Rated at
Actual power output
WOW thats quite a Huge Diference.
Where do you get info like this I would like to see what people are getting from the amps I have in my sig.
The Eclipse is slightly underated and the Hifonics is slighty overrated.
GReddyBooSTer
GReddyBooSTer
FL
stones
