Amplifier help
AflacDuck
I am installing my first amplifier and subs and I have come to a road block and I was hoping for some help.
I am installing a Power Accoustik 1600w amp on a set of 12's. I have a stock head unit so I had to get a crossover. I spliced into my 2 stock 6x9's to run into the low level inputs on the crossover the ran the red and white high level outputs to my amp.
I am confused as to what I do about the remote wire though. Someone told me I can splice into the positive on one of my speakers and it should function properly. then if that works do I go to the amp first or the crossover first.
Also, do I just jump off of the power and ground from the amp to the crossover or do I have to run a separate power and ground wire just for the crossover?
Your best bet is to tap out of the fuse box. Just use a light tester and find one that is only active when the key is on. If you are using a regular crossover that requires a power and ground then you can tap off the amp if need be. (distro block would work best)...then just run a remote wire to them and done.
AflacDuck
AflacDuck
Muncie, IN
pro-rabbit
vegang
vegang
