Amplifier for a Visonik 3000w sub
mxsi64
Hi all I am kind of new in this, I have bought a V815D2 3000w 1500rms 15" 2 ohm sub, and I have another 3 pioneer 600w 10" 4ohm subs, I know I have to buy an amp only for the Visonik, but I do not have much money for it I want to know what amps would you recommend for this sub, I have something like this in mind, is a BOSS GT2500D, wich acording to the specs says:
CLASS D MonoBlock Power Amplifier with Remote Subwoofer Level Control
Max power, 2ohm: 2500W x 1
RMS power, 4ohm: 900W x 1
RMS power, 2ohm: 1500W x 1
Frequency response: 20-1500Hz
Signal-to-noise ratio: >100dB
Dimensions: 9-3/8"Wx2-5/8"Hx12-1/2"L
Remote subwoofer control
Line out (for system building)
Variable low pass crossover (24dB/oct)
Variable subsonic filter (24dB/oct)
Phase switch
Wich sales at ebay at 114.00 + 23.99, or something with enough power to take this sub to the max, also whant to know if you belive this one can get my sub to the max???, for the other ones I do not know if this should be god for them:
Crunch
PowerZone Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 125 watts x 4 chan.
2 ohms: 200 watts x 4 chan.
Max power output: 400 watts x 2 chan.
MOSFET power supply
LED power and protect indicators
Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
4/3/2 Channel operation
Stereo / Mono Amplifier Mode Switch
Rugged MOSFET Audio Outputs
Preamp RCA Outputs
Overload, short, thermal, and DC protection
Standard heatsink cooling
Silver-coated RCA level inputs
Variable high-pass filter (60-1200 Hz, 24 dB/octave)
Variable mono low-pass filter (30-250 Hz, 24 dB/octave)
Frequency response: 30-1200 Hz
or this
Crunch
RMS @ 4-Ohms: 100W x 4-Ch
RMS @ 2-Ohms: 150W x 4-Ch
RMS @ 4-Ohms: 300W x 2-Ch
Dynamic Music Watts
SEPP A/B-Class PZi Amplifier Designs
Bridgeable Designs
Illuminated, Large New Design Crunch Logo
PZi. MOSFET Pulse Wave Modulated Power Supply For Instant Maxx Current Output
2-Ohm Capable A/B Class
Config to 3-Ch R & L and Sub Mode
PZi Amp Protection with System Diagnostics LED's That Protects Against: Current / Amperage Overload, Short Circuits, Thermal Overload, DC Offset
Hi-Level Speaker Lead Inputs
Silver Preamp Level RCA Inputs
Daisy Chain Line Outputs
Versa Cross Sound Shaping Controls: Mono/Stereo Switch, HP/LP/Full-Pass Freq. Selections, Crossover Frequency Adjustments: 60 Hz to 1.2kHz (30 Hz to 250 Hz Low-Pass)
Separate F & R Bass EQ Controls Adjustable +12dB Bass EQ @ 45Hz
Input Level Control (0.2 to 5V)
Oversized Speaker Terminals
or this soundstorm
RMS Power Range : 720 Watts
Number Of Channels: 4
Maximum Power: 1000 Watts
Low Frequency response: 9 Hz
High Frequency Response: 50000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Tri-mode operation
Bridgeable
2 Ohm Stereo Stable
Variable low pass crossover: 40-150Hz
Fixed high pass crossover (200Hz)
Variable 0 to +18dB Bass Boost
Variable input gain control
Power and protection LED indicators
Thermal, overload and speaker short protection
Illuminated blue logo
Line and speaker level inputs
Chrome plated RCA connectors and screw terminals
Remote subwoofer level control
all those amps ****.
DO not buy any of them
contact this guy tcguy85 and see if he has the kicker 750.1 this will give you around 900rms for $150
Those amps are all a hundred dollars for a reason, they are just waiting to let out the magic blue smoke.
That sub is not gonna take 3k rms and thats why real 3k amps are almost a grand for real power. see this http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=152
You get a legit 1k on that sub and its gonna wang. see the zrs10 above - real power.
check classifieds here like crazya nd check their feedback well.
thanks man
ZRS10 $250 shipped
2500X1 and easy on electrical
mxsi64
mxsi64
El paso, TX
AsianInvasian42
