amp
  • Thread starter Unregistered
  • Live activity
  • Replies 3
  • Views 806
Yes, you just use the factory speaker wires. But you need a line out converter (LOC). It converts your speaker wires to rca connectors. You can find cheap ones at wal mart for like $10
you can do it but it is a lot more to do then just hook up the speaker wires to the line out converter, it is a lot more time consuming then running an amp off a aftermarket HU, you must also run a remote wire for the amp bc the facter HU wont have one that involese running a second much smaller (like 16 gauge) fused wire off the battery and to a switch and then to the remote spot on the amp also it take a bit of adjusting on the amp to get the sound right when using the converters for the RCAs.
Guest
mrray13
firey_kimchi
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
