amp wont work
borisshnitkin
nj
i just installed my 2 type r's in a new box and for some reason the amp doesnt want to work. the light wont even turn on. i first thought it might be the protection mode but it is also not on. i work in circuit city and the guys there have no idea whats wrong. one said that there might be a problem with the wires. another said that it could be the amp. i started to get this problem just when i first got this new box. maybe i wired the subs wrong i dont know. the subs are dual voice coils. and the amp is a us accostics 800f. here are the specs for the amp......
RMS, per channel @ 4 Ohms @ 12.9v input 300Wx2CH
RMS, per channel @ 2 Ohms @12.9v input 400Wx2CH
RMS, Bridged Mono @ 4 Ohms @ 12.9v input 800Wx1CH
how should i wire the subs in the box with this setup to get the max power.
i also installed bass blockers for my speakers cause they are the factory ones, could the problem be that the wiring be short in the back (the remote wire) i dont know guys, im so pissed off right now. please help.
maybe there is a short in the wire's,who know's.
give me some things i should try to get this amp to work.
also when it starts to work, around 10 min or so the amp would stop working, not even go into protection mode or anything. please help!!!!!!!!!!!
double check all of your wires, including the power, ground and remote. triple check them, that they're secure, and not touching each other at any point. (do this at the HU, too). check your fuses too, both on the power wire, and in your amp.
abe m.
i just went to test if it was getting power with a meter and then all of a sudden i see the power ligth turn on. im wondering why it would work if i try and test the power wire and the remote wire with a meter and then all of a sudden i see that the power light turns on.
what does that mean and how do i fix this problem.
borisshnitkin
borisshnitkin
nj
borisshnitkin
