amp wont work.. all power
shynegrynd07
Eyedea and Ability
so i got an amp from my friend because he said it doesnt work. i hooked up a 12 v. power supply and used a meter and all the connections and outings are getting power. however, the LED "On" light will not light up even though power is going to it. also the fans will not turn on even thought they to are getting power.
any suggestions?
oh yeah, it is an A3200E Audiobahn Amp (i know, a lot of people on here dislike audiobahn, but it was free:))
Open the amp up and give it power. Trace the leads on the board and follow it to see where you stop getting power.
see thats what i did.. and the power goes all the way to the outputs and inputs, the gain and the crossover lol its rediculously weird.
and i might just be retarded and not know exactly what a remote is, but idk where it is or if it has one..
remote turn on. its the 12v signal that tells the amp to turn on
thats what i thought it was. but either i can't find the remote or it doesnt have one.
is it like.. obvious? do i buy one and install it? if i have to buy it and install it, where would i solder it to?
as you can see the power is full. there isnt an REM thing anywhere.. only thing close to that is REF 12v for Reference voltage..
its like i need to turn on a switch that i cannot find!
im so confused..
See in the first pic you posted, between your white and black wires you have for your power and ground, that other terminal in the center is for your remote wire. Run 12v to that and that's the "switch" you need to turn on.
i have the main case, i took it out to work on it.. i'll put some power to the middle and see what happens!//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif ? Forget it then. But that that's your remote turn on //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Don't try it and keep playing around with other shit until you break something.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Your amp won't cut on without it.
shynegrynd07
Eyedea and Ability
shynegrynd07
akron, oh
05fronty
