ultimate157
Engineering Student
Not sure how the circuitry is setup, but...wat ? the behavior you describe is quite contrary to Ohm's law..
That amp has an unregulated power supply and the rail voltage and power output is going to be proportional to input voltage.... The amp is not going to pull more current as voltage drops, it's going to pull less...
Even if it was a tightly regulated amp, it would be designed to work reliably with the PSU switching at 100%...
If an amp is trying to output the same power as voltage drops, then current will have to increase to keep output the same.
