Amp won't power on
I was having trouble getting it onto the remote turn on lead from the HU, so i put it on the little wire that powers the HU. Shouldn't that work?
check on ur amp if ur getting any voltage on the remote wire on the amp. if u haveing trouble still getting the remote wire tap into the radio fuse on ur car fuse box.
to check and make sure things will work take a peice of speaker wire and run it from the power wire to the rem on the amp if it turns on then your problem is your remote if not prolly a ground
Kev4029
Kev4029
Colorado
dleccord
vegang
vegang
