Amp wiring question?
MarshBear
I bought this small amp (Kenwood KAC-M3004) to go in the front of the vehicle.
Wondering if I have to run a separate power wire from the battery, or If I can just splice the 18-20 gauge wire that running to the headunit or just use 12v power wire that runs to the "cigarette outlet" that I never use.
Nope. The correct way would be to run a separate power wire from the battery with a inline fuse in between then to the amp.
I'm aware of the "Correct" way.. But the question was is it possible to just use the 12v power wire already present.
So if your aware of the "correct" way, then why did you ask? You sound like you know the answer already.
Depending upon the amp's wattage, the better solution would be running a separate power wire from the battery to the amp. If the amp accepts up to 8 gauge wire, then run that.
Running thin power wire (18-22 gauge) is asking for a fire hazard. Will more than likely burn your car to the ground due to lack/insufficient proper gauge wire.
MarshBear
MarshBear
Alabama
Boomin_tahoe
