amp\wiring question for my jl 12w6v3-d4
Fezteh
Hi i have a 09 tl and I just bought a 12 W 6 v 3-d4 JL sub in a ported enclosure. it came with a VOLFENHAG ZX-5161 2-Channel 1000W Element-5 Bridgeable power Amplifier,and a PAC SOEM-T 2-Channel Premium Line-Out Converter with Remote Turn-On Trigger my questions are this: is The amp sufficient for this subwoofer (if not what would you recommend) and what gauge wiring would you recommend for the power line and what kind of fuse thanks in advance guys.
Subwoofer specs:
Size 12 -inch
Impedance 4 ohms
Cone Material Mineral-filled IMPP
Surround Material Rubber
Ideal Sealed Box Volume (cubic feet) 1.105
Ideal Ported Box Volume (cubic feet) 1.405
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil Yes
Sensitivity 85.4 dB at 1 watt
Frequency Response 20 - 200 Hz
RMS Power Range (Watts) 200-600
Peak Power Handling (Watts) 1200
Top Mount Depth (inches) 7 9/16
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 11
Vas (liters) 54.37
Fs (Hz) 26.919
Qts 0.463
Xmax (millimeters) 19
Amp specs:
Max Power Rating: 1000 Watts
Built-in Full Crossover
PWM Mosfet power supply
High Efficieny Die-Cast Heat Sink
Overheat and Short Circuit Protection
Power and Diagnostic LED Indicator
Soft Delayed Power On
Tri-Mode Capability
2 Ohm Stable
THD Distortion : 0.05%
Frequency Response : 20Hz - 20kHz
Input Sensitivity : 0.2V - 6V
Input Impedance : 10k ohms
S/N Ratio : 90dB
Channel Separation : 50dB
Remote Gain Control : 0.2V - 6V
Crossover Network:
Low Pass Filter : 45Hz - 300Hz
Bass Boost : 0dB - 12dB
High Pass Filter : 45Hz - 300Hz
Fuse Rating : 25A
Dimensions: 298 mm L x 245 mm W x 61 mm H
nah that amp will prob be okay to run your speakers, but i'd suggest a bigger monoblock amp for your sub, also i'd suggest 4gauge minimum for your wiring (best of with 0 gauge)
I'm keeping the els speakers for the time being the amp is for the subOh also I know the hd750 would be a good choice but I'm looking for something more affordable assuming the volfenvag isn't sufficient
hang on i'll have a look at the amp specs, google is your friend..... it only has one 25a fuse in the amp, and it's 1000w max... so it'll prob put around 3/400 watts rms bridged at 4 ohm into your sub. the sub needs a minimum of 250 wrms.
it will work, but i'm only guessing what it's rms rating is
Oh idk how i missed the rms
But i was looking and this is all I could find:
Specs: Details: Description:
Peak Power handling 1000W
Amp Power Peak (Watts) 500
Maybe that is it?
if you Come to the conclusion I should run a different amp do you have one you would recommend that would work for it?
Oh idk how i missed the rmsBut i was looking and this is all I could find:
Maybe that is it?
that amp's not gonna have close to enough juice to tickle those subs. give us a budget first for recommendations.
Maybe that is it?
Completely true, that amp is not even close to enough for that sub.
Fezteh
Fezteh
United States
Fezteh
