amp wiring help
pbnj22
ok so i have a sub and mono amp in my trunk and i just bought some speakers that are 50 watt rms and i need a 4 channel amp to power them. so my question is what wiring do i need for my new amp? do i need another power cable or rca cables or what?
You need a Distrobution block for the positive(+) and one for the ground (-)
You need a RCA cable to go from existing amp's RCA output to 4 channels input
Also, you need to jumper the remote of the existing amp to the new amp.
You need a Distrobution block for the positive(+) and one for the ground (-)You need a RCA cable to go from existing amp's RCA output to 4 channels input
This is one way to do it, assuming you have power flow to spare on your current power wire.
What kind of power is the monoblock pushing, and what size power wire does it have at the moment?
Depending on the 4 ga running 1000w is fine.
People of here like to overkill (1/0)
Of course I have ~110AH in batteries and 1/0 for 1500w //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pbnj22
pbnj22
Duluth MN
pbnj22
