03 Acura TL
I'm going to be running an Alpine PDX 1.600 and a PDX 2.150 (less than 1000 watts total) and wanted to know how i should wire them. I was planning on using 4 gauge wire from the battery and then connecting a distribution block with 8 gauge wire going to both amps. However, a guy at the local shop just said to run a 4 gauge to the mono amp, and an 8 gauge to the 2 channel. This way if one fuse blows there is less trouble shooting to see what the problem is.
So is it ok to use two different size wires for 2 different amps instead of using a distribution block? Is there any harm or benefit in doing so?
