Amp wired to .01 *WTF!?*
well he siad he was getting 1.4 each coil but .01 when he hooked em all up
that tells me he hooked up the coils wrong //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif he crossed a wire somewhere i think...dead short is .01 on most dmm's...
Coils^ supposed to sit @3ohm but I guess these are apparently 2.5 ( which is fail because I was hoping for final load of .75)
^Wired up... and drops down to .02
Touch the leads of the DMM together, 90% of DMMs won't read perfect resistance. If you touch the leads and it reads 0.5 like mine does, then subtract 0.5 from the final value.
As for the 0.01 issue, it sounds to me like the batteries in your DMM are low, but you seemed to have disproved that when you tried two different meters and since you are getting a realistic reading when directly connected to the subs.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
142
  • Locked
326
Amp
326
Mr.SoloDolo
Mr.SoloDolo
Marin County, Ca
lilboom
    May 18, 2024
    May 18, 2024
