Amp upgrade help
Tikfes
Hi all, i have a boss audio amp which is not very ideal for this setup or any setup according to my installer, therefore ive decided to go on the search and post up my setup here in hope to get an amp which can power this setup effectively,
Here i have the front, headunit and rear door speakers, parcel shelf too
New Pioneer TS-A1604C 6.5" 350 watts Seperates Component splits
Component : 6.5"/6.75” Separates
Type : Speakers and Tweeters
Power Handling (Watt) : 350W / 700W
Power Handling (RMS) : 50W / 100W
Impedance (Ohm) : 4 Ω
Frequency response (Hz) : 29Hz – 29kHz
Sensitivity (dB/SPL) : 90
Mounting Depth : 2-1/8"
Cut-Out Dimensions : 5”
Cone Material : Carbon Graphite Aramid IMPP
NEW PIONEER DEH-X6550BT BLUETOOTH BT CD MP3 AUX
Type-S 6-1/2 (17cm) 2-Way Coaxial Speaker with Grilles
Features
- Handling Power:
Peak: 240W
RMS: 80W
- Butyl rubber surround for natural response and stability
- Fits 6-1/2" and 6-3/4" speaker openings
- Aramid reinforced TIL bobbin holds voice coil wire very rigid
- 1" Silk dome tweeter
- Swivel-mount tweeter
- Neodymium tweeter magnet structure
- Low distortion strontium woofer magnet
- Frequency response: 70-22,000 Hz
- Sensitivity: 88 dB
- Top-mount depth: 2-1/4"
- Impedance: 4 Ω
I have pioneer 6x9 350watt speakers however have forgotten the specifications of it,
So i was just wondering what amp you guys could recommend me and maybe what is the minimum amount of watt amp i should be looking for, for this setup. Cheers guys.
Btw i do not plan on putting subwoofers.
Any good 4 channel will do, I'm a little confused as to 3 sets of speakers though... What vehicle is this set up in? If anything amp the 6.5's and run the 6x9's off hu power as rear fillers
Thanks, it is a holden commodore 4 doors, if anything i can say it looks like a gto monaro except with an extra door haha, i was looking at the pioneer gm-D8604, but unsure as the installer recommends a polk branded amp for around 300$AU
Tikfes
Tikfes
Australia
Tikfes
