Amp turns off... still
So thought I would update this.
I traced the alternator wires and found no issues, checked my terminals again and tightened anything and everything down, redid some ring terminals, but no change. I've decided to bring it to my stereo guy to see if fresh eyes help. Before I bring it to him though I will be swapping in a new regulator and possibly opening up the spare alternator and putting my electrical engineering to the test. Anyway I'll get back when I have an update
So I thought I'd update this.
I ended up finally fixing the issue after buying a mechman alternator. so there you go my fellow f150 5.4 owners.
Only the mechman regulator seems to be able to keep up with the the truck.
For documentation sake I fixed it well using a 1000cca agm battery, 1/0 cable all the way through the electrical system, and a belt that is 1/2 inch smaller then the original (2008 ford f150 lariat fx4)
Maybe i missed it; what brand were your first two high output alternators?
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
205
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
239
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
188
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
425
Spazz131
CarAudio.com Recruit
Spazz131
Michigan
Spazz131
    Apr 26, 2024
    Apr 26, 2024
