amp tuning? subsonic???
Subsonic keeps freq levels that are too low from getting to your subs, generally with ported boxes its nice to set the subsonic 10 hz under whatever your box is tuned to, so since your tuned to 38hz, set the subsonic to 28hz. by crossover do you mean High pass, i would set it at anything between 60 and 80, it dependz on where your mids are crossed.
set the lowpass o the amp around 80hz...make sure its a clean signal going to the amp...DON'T USE DECK OR EXTERNAL CROSSOVERS BEFORE THE AMP........OR YOU WILL SCREW UP THE SLOPES
is it teh lowpass, i get them conufsed lulz. but he is right.
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
82
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
memphis_vette
memphis_vette
Redding, CA
Johnny Law.Lulz
