amp to woofer connections
  • 4
kingpin_jeffie
i need a vacation...
1,243
Erie, PA
alright my cousin just picked up a Profile 800sx 200x2 and hes gonna wire it in parallel to a pair of Infinity Reference 12's to give him 300x2 @2 ohms now the question is what guage power wire should he get? also what guage speaker wire should he pick up?
thanks for your input
for the batt to amp i'd go w/ 8 ga
from amp to sub 12 or 10 probably 12 though....good luck
also make sure you put a fuse close (probably w/ in 10") to the batt...
Yeah I'd say the 4 gauge... one more thing, check the rms on those subs. If I remember correctly the rms is below 200 on each. If this is true then you dont have to bridge the amp, thus keeping a 4 ohm load, keeping cleaner output, and allowing the amp to run hotter. Just a little concern before something bad happens, like blowin 'em.
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
168
  • Locked
402
Amp
369
kingpin_jeffie
kingpin_jeffie
Erie, PA
StallionAudio
    May 20, 2024
    May 20, 2024
