Amp to run with 2 12'' Kicker L7's at 4ohms
Nice man I like the jeep! The stock alternator that came with your vehicle should have plenty of amperage to supply the stock accessories, with a bit of excess. Which hifonics did you end up going with?
Thanks thats my main hobby but who doesnt like a nice sound system in it? Well I went with the hifonics 1700.1 but then an Alpine PDX-M12 came up in the classified and I picked that up for 300 and worked it out with the seller of the 1700.1 to not end up getting it. Worked out for both of us. The Alpine is what I really wanted but the price was way to high... Until this one popped up. So ill be running them each at 600 rms at 4ohms. For an everyday system id rather do that then 1 ohm. And a have a bit more than stock accessories. and will have more to come. Running a winch, lights, compressor, lockers, and more all off it would kill it.
damn, you're already gonna have some serious amp draw from those accessories. at least you won't be bumpin and using your winch at the same time. Winches use serious power if I remember correctly.
Sounds like you've got it figured out man.
post pics of the install when you get it done.
Yea I definitely do. A dual batter set up is to come soon. The winches grab a TON of power. Took long enough and a little more than I wanted to spend but its figured out. I was going to build a custom box but I cant make it the size I need to so I am trying to find a kicker box and then I will do custom boxes,storage,etc around that to make it fit tightly where I am putting them. Now just to find that box.
Brandon1024
Brandon1024
Chicago
Brandon1024
