amp temp and thoughts- orion 25001d
mhyde71
PG FanBoy
so i measured my Orion 25001.d (just bought 2 of these)
at idle, no signal even being tied into amp
and it read 132f
isnt that hot for amp at just idle? or is it hot bc of it being a 2500w amp? but it wasn't making 2500w at the time- like i said no signal rca even connected. so is something wrong with amp?? or do these orions just run hot ??
was thinking that maybe someone with these amps might know that they just run hot or smth??
cheers
and it read 132f
cheers
sounds like you got a dud. No good amp should get hot just by sitting idle.
well i mean it does work
But idk does seem really hot
I haven't done extensive testing ... i came here to see what folks thought
i hope not
tomorrow i will try out the 2nd amp and see if get similar results for temp's
Some Korean half bridge amps will get hot idling but typically that''s like after an hour or so. If yours is getting hot fast there's something wrong. Hopefully they'll warranty it.
so i have some update on this here
and thx to those that responded.
so here's the dealio
when i hooked that amp up - (1st off these are used off craigslist, and from far away, had friend middle man them to me and i just got them in few weeks ago)....but when hooking up the first one, the one i initially posted about... i hooked it up to power - without turning the power off. this is on test bench with 50a power supply.... but/and/so there was a big snap of crackle of spark- i figured that happens lot when the caps are like fully discharged.
so i continued, payed it no mind, kept power to it, and got warm, took infrared meter out ... it was 137f as you see in pick- and came here to get ppls feedback
today i tried the 2nd amp
this time i turned all power off, discharged the caps - or watched them discharge bc of the leds in the d-block
but hooked it up, and turned it on
no big crackle of spark this time... and the amp has now sat for 30 min and not warm at all.
so i said maybe thats the deal- lets not hook up that 1st amp with power on... so i did it the normal person way...turned off power and no spark and amp didnt get hot really at all... lil warm at idle after 30 min or so... but not 137, more like 82f. the ambient temp was 55 or so
So long story short... i think it had something to do with not turning power off when connecting power acc and ground.
so i think it is all okay
tomorrow if chance i will connect up subs and signal and see if it stays temps decent like
thx guys
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
187
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
226
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
171
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
413
mhyde71
PG FanBoy
mhyde71
Brattleboro, VT
mhyde71
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
