Amp Suggestions :D
This is the first system I've ever put together and i dont have alot of funds at the moment. I just bought:
2x 12" Audiobahn AW1251t @ 400w RMS/800w Max Output, 2x Dual 4ohm coils
And was wondering what kind of amp wattage should i be looking for and what brands? Also id like to keep it under 150$ new.
I think those are dual 2 ohm because the list them as 4 ohm drivers. If that's the case you can run them at 2 ohms. Based on the listed power handling, any amp that puts out between 800 and 1600 watts @ 2 ohms should work. For that price range you're kind of limited.
Here's one that fits your two criteria.
http://cgi.ebay.com/KENWOOD-KAC-9102D-1700W-MONO-CLASS-D-CAR-AMPLIFIER-NEW_W0QQitemZ120076246669QQihZ002QQcategoryZ79828QQtcZphotoQQcmdZViewItem
Just be aware of the different output numbers that some people are advertising for that Crunch amp. Millionbuy's numbers for it are:
RMS Output Power Rating :
* 350W x 1 @ 4 ohm
* 700W x 1 @ 2 ohm
* 800W x 1 @ 1 ohm
If you just ran one of those 4 ohm subs the amp would see 4 ohms. That crunch amp would put out around 350w and the Kenwood would put out about 500w.
Xtremes10
Xtremes10
Hiram, Georgia
evan
michigan born
    May 14, 2026
michigan born
    May 14, 2026
