Amp suggestion
I have currently narrowed down my long awaited search for a mono amp to two. Either the JBL 300.1 or 600.1. It is going to power 1 JL audio W6 AE 10" that requires 300 watts rms. I am not looking to over power the sub, just get it the power it deserves. Your help would be greatly appreciated. Thanks
that sub is dvc 3 ohm right? So if you go with the jbl300.1 you get a 1,5 ohm load which would work nicely.
That is what I will be running it down to. Or it could go up to 12ohms. I was thinking that the 300.1 would be enough, but I just wanted to make sure. Thank you very much for your help.
Once again, thank you very much for your help. Now it is just time to save up a little bit more and get the 300.1 and the 80.4 and begin my first fiberglass install on my Grand Am. I do appreciate all the help that you have given me.
No, am going to go with a sealed box. I really want to have a clean sounding enclosure and it will also allow me to fiberglass a small enough enclosure that will allow me to keep my trunk. I got the sub for less than $70 and I am going to be fiberglassing on the rear side of the trunk.
Well, once again, thanks for everyone's input. I am going to get the JBL 300.1 and the 80.4 for my fronts. I plan on getting the fiberglass and begin building my enclosure as soon as I have some time (military and Papa John's takes up a lot of my time right now). I plan on building the enclosure first and getting everything I need prior to picking up my my amps (4ga wire kit, 2 distribution blocks for my power and ground, and mdf to build my ring and amp rack). It has been a long time since I have done installs and I am looking forward to this project. Next, will be to install a similar setup in my Grand Cherokee. I am just hoping that fiberglass is as much fun as it looks.
Prozac
Prozac
Colorado Springs, CO
DaBaller504
