Amp suggestion
Racer24x
I would like to purchase a Memphis Car Audio M3 sub. But i don't which amp i should purchase to go along with it. I will be runnin' only one of these in my car. Any suggestions?
Sub Specs:
Continuous Power Handling: 400 watts
Maximum Power Handling: 800 watts
Sensitivity (2.83 volts): 89.15 dB
Magnet Size: 85 oz.
Mounting Depth: 5.6"
Voice Coil Configuration: Dual 2 ohms
Thanks
Since you have a Dual 2 Ohm sub which has 400w continuous power handling (rated) you'll want an amp that outputs between 350w-500w @ either 4 Ohms or 1 Ohm. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Weeelll.......what kind of budget are we working with here?
It will be both easier and likely less expensive to source that particlular level of wattage at a 4 Ohm load rather than a 1 Ohm load.
Your cheapest out will probably be a two-channel amp running in mono bridged mode. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Racer24x
Racer24x
Missouri
Racer24x
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
