Amp, Sub Wireing Help
TripKore
Well, I finally installed my new mono amp for my subs. But the Amp is way to powerful for these subs, so a few people told me to wire these two ways to help not blow the subs...
1.hooking up the - of 1 sub to the + of the other sub
2.then hook up the + of 1 sub up to the + of the amp
3.hook up the - of the other sub to the - of the amp
and
1. positive of each sub to positive of the amp.
2. negative of each sub to negative of the amp.
I wired both ways, and both ways theres hardly any bass at all. So I come here to ask you experts, see if i can get more suggestions and help.
System:
Hifonics XX-ZEUS Mono D Block 1600watt amp.
2 Rockford Fosgate 12' 400watt 4ohm/Single Coil Subs (Boxed)
http://www.tripkore.com/images/carsystem1.jpg
http://www.tripkore.com/images/carsystem2.jpg
just wire them in parallel, from the sub box use the + to the + on the amp and the - to the - of the amp then the other sub the same on the other channel i used to have those subs before, when wired in parallel they hit nice;)
I thought i did do that already, and they weren't hitting. I'll try again. Yeah for the past year i had them bridged on 2 channels of the MTX amp there, only 200watts, but hit hard surprisingly. Think these subs are going on 4, 5 years old, still in mint condition heh.
Well i re-wired to parrelle again, and the bass still isn't hitting hard. Maybe its the amps settings, i must have hit something while i was screwing it up to the board.
just wire them in parallel, from the sub box use the + to the + on the amp and the - to the - of the amp then the other sub the same on the other terminal. i used to have those subs before, when wired in parallel they hit nice;)
Fixed.
Most likely you haven't set the gains correctly.
the rms rateings on subs dont mean a thing, just a pointer..u give the sub what it can take, not how much it says...if u think ure overpowering them turn the gain down, listen to it for a couple of days then turn it a lil up...repeat the process when u feel they are done:)
Thanks for the tips, how can i tell their on the verge of being blown? Like i said, i have 1600wat amp, 400wat subs (wired parallel). They start to sound flat/fluttery or pop/cracking noise?. Right now they sound perfect, been messing with the amp settings all day, they bump, just dont want to blow them before i buy new subs. Think i need to get some foam installation for the trunk, there's alot of rattling now than before.
Don't listen to him. Set the gains accordingly.
TripKore
TripKore
Boston, MA
ultimate157
Mike Mccabe
Giles
    Jun 27, 2026
