Amp stopped working while driving...
gangstajpimpin
Ok, as the title says my Alpine amp stopped working while i was driving.
All fuses are ok.
The input voltage was measured at 12.4v with car off
RCA cables are good.
Amplifier grounds are good. (Other amp's ground is hooked up to same spot, so its good (sanded down to metal and bolted down really good on chassis))
Output voltage to subwoofer is 0v //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Gains were also set properly, and my IDQ was receiving 400w.
What could be the problem?
Power is 12.4v at the amp...so fuses are good, i replaced both 30A fuses on the amp as well, blue light is lit up, its just not putting any power to the output of the amp //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I have signal coming from my deck because i swapped my comp rca's for my subs rca's
ok then you might want to open your amp up to see if your output fets are bad. did you smell anything burning? you are positive your ground is good also?
10
313
285
160
gangstajpimpin
gangstajpimpin
Las Vegas, NV
IDSkoT
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
