Amp starting in protect. :(
Pumper
**** just took it to a BestBuy and the guy who's been working in car audio for years... worked at Car Toys prior, said he did everything and it has to be something wrong with the amp.
I told him how I tried to wire my power and ground cable. I didn't use a fuse for the power, he said that may have done it. He said if I opened the amp that I will probably see black marks. But he told me not to do it b/c it voids any warranties. So I'm called audioque and left a message.
Amp: aq1200d
Sub: SSA Icon 15
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Is my amp fried? It won't come out of protect.
Hmm. None of the fuses are blown so he was saying there has to be a fuse inside the amp that is blown or something.
WTH why is it not going in power mode, instead of protect? Would taking a video of my sub/amp and posting it help?
Alright I'll wait for AQ to call me back.
Basically what happens when I start the car is that the protect goes on, then the green light power goes on, then it goes back into protect and it stays in protect. All in less than a second.
did you try with the sub unhooked, just power/ground/remote? also, do you have a dmm to check voltage at the terminals?
When you say sub unhooked... that means the + and - cords are not plugged in correct? I have not, I will try that though. The guy at bestbuy checked voltage, he scrapped the paint in my car and grounded it to somewhere else. It consistently read 12, rather than before which read 10 and then dropped to 6-7.
in that case, definately try it with the rcas unhooked. i bet those are cooked, from the amp trying to ground through them. there may also be damage to the amp already, too. start there, though.
Pumper
Pumper
Denver, co
akheathen
