Amp Spec Question, please Help
I would use the 12 volt rating if it is given. It is more accurate then the 14 v rating (your alternator probobly wont output more then 14 volts if you have all of your stuff running). The 14 volt rating is strictly for marketing purposes so the manufacture can make their product look like it outputs more power then it really does.
No, you can't "choose" which one to use. Most amps put out more power at 14.4v because they are getting more power from your eletrical system. Your electrical system usually puts out 14.4v, unless you don't have the car started then it would only be 12v, so the amp is probably producing 800 watts, as long as it is a reputable company like jl, alpine, ppi and not legacy or pyramid who usually overate their products.
when the car is running it is producing 14.4 volts. The battery itself runs at 12 volts, however when the car is running the alternator is recharging the battery plus running everything else that is electrical. In order to do this it has to put out more power than just the 12 volts. My car consistently is above the 14 volt point on my dash. Sometimes its even close to 16 volts. Does this mean my car isn't putting that much out, and that my amp is not getting that much? No. The 14.4 V is not BS. It's just saying that if your amp is recieving 14.4V than that is the power it will produce.
Edit: By the way my electrical system is complete stock, even though its 105 amp alt, but my car has many accesories and power everything
hondaracer1976
hondaracer1976
Rockledge, FL
VTEC11
