Amp sometimes plays, then shuts off
tristanlee85
This happens sometimes as soon as the first low frequency when the sub hits hard, it will shut off right then and the sub will not play until I turn the car off and back on. Then, after that it may either go right back off or stay on. Also, it doesn't always shut off in the first hit. I can play it for a good while and it will shut off as well.
I've checked all my connections to the sub, amp, everything. They are solid. I notice when the sub goes off the amp is still on, but the 'protection' light is on. Does this mean it is shutting off to protect the sub, or is there something internally wrong with the amp? I know it isn't because it's over-heating because I have 2 fans directly on the components of the amp.
No. Well, the amp may be putting more power into the sub than it can handle. The sub is rated at 700rms and the amp is 900rms @4ohm
An amp will not such down if the power it is giving to a speaker is too much, or more than the subs RMS, it is not that smart. //content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif It will however shut down if there is a short on the VC, or anywhere else in the system or if its gets too warm.
tristanlee85
tristanlee85
Columbus, OH
tristanlee85
