Amp shuts off then flickering on/off
joeb1983
I have a visonik V8212 AMP the spects are as follows i am running 2 "10" sub SONY XPLODS XS-L1000B Max peak is 650W i have briged the subs as well they sound good but i changed so of the wireing and first i blew the inline fuse next to the battery i thought it might of been from reconnecting it while the battery was connected but i did not blow then it was later when i was driving when i raised the volume i could not idenify the Amp on originall fuse so i put a 40A in the problem im having is during volume increase it shuts off and flickers like it can't turn on i don't know what i did wrong i just replace speaker wire and bridged the unit here are my speces
Number of Channels 2
RMS Power (4 ohms) N/A
RMS Power (2 ohms) N/A
RMS Power (1 ohm) N/A
Bridged RMS Power N/A
Total RMS Power Output 400 watts
Peak Power Output 800 watts x 1 channel
Total Peak Power Output 800 watts
Minimum Impedance Unbridged N/A
Minimum Impedance Bridged N/A
THD at Rated RMS Power N/A
Speaker Level Inputs N/A
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency N/A
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote No
Fan Cooled No
Fuse Rating
My power wire is a 6 gage amp wire from battery to amp with 40 Amp fuse im using a 8 gage for ground and 14 gage remote wire with 18 gage speaker wire
What is proper wire gage i should use if wrong and size fuse
Ground should be the same size or larger than your power wire. That's issue #1. Visonik amp + Sony Xplod subs + Schosche wiring kit = disaster. No matter what way you look at. Browse this forum, sell what you have you, save up some money, and try again.
this also true. check out Amp Installation Kits, HDMI Cables for a real wiring kit at a very good price. but until then check and check again your wires,and fusing
joeb1983
joeb1983
Hesperia CA
150dbs
michigan born
    May 14, 2026
michigan born
    May 14, 2026
