Amp settings?
Junglistjed
amp is powered up! had to connect the remote wire to a yellow one as it wasnt getting power from the HU remote , not all i need to know is what i shiuld have the settings on! amps got these controls
level, subsonic, bass boost, LPF 50Hz to 250Hz, H.P.F 80Hz to 1.2Hz
im powering 2 x hifonics brutus - 12SQD4
12" DVC 4 Ω 1200 W MAXX 600 W RMS
they are dual coil
Since you are powering subs, switch it to the LPF, and you could set it to about 80, every system will be a lil different. You wont be using the HPF
The level should be the gain, you could set that with a DMM, you could search it.
Bass boost, I usually don't use it at all. But if you find you dont have enough bass, you can turn that up a lil bit. Just listen to the sub while you turn it up, if it doesn't sound to happy when you turn it up, then turn it back down.
Ive never had a amp with subsonic, but I believe you would set it to maybe 20 or 10.
thanks alot mate, any idea on the HU settings , theres quiet a few including bass and treble
you need to change the remote wire location. yellow is battery constant meaning the amp is ALWAYS on. that is bad. you could go to the red wire so the amp turns off with the car. did you use the blue/white wire from the head unit? the blue wire is power antenna and only on when on radio (not CD).
what HU do you have?
ye i have connected it to the red now
im currently using > Halfords | Pioneer DEH-1300MP CD/MP3 Player
but my more expensive one is > Pioneer DEH-P7100BT CD Tuner With USB and Built-in Bluetooth Handsfree £234.88 including VAT. DEHP7100BT. Buy discounted car audio online at In-Car Express
Junglistjed
Junglistjed
los angeles
keep_hope_alive
