Amp settings
BamBam28
AL
Ill start with what im running.
Sub - 1 12" Orion H2 2000WRMS
Box - 2cf tuned to 32Hz
Amp - US Amps Merlin MD1D 1200WRMS@14.4V (older model a little underrated I think... maybe 1300@14V)
My question is about the amp setting, LEVEL .1V-6V, SUBSONIC 15Hz-40Hz, LPF 40Hz-250Hz & BASS EQ 0db-12db
Im not realy sure about the LPF 40Hz-250Hz... but the rest I have set up as follows:
Level 2V
Subsonic 20Hz
LPF???
Bass EQ 2db
What should LPF be set at?
what's the slope? i wouldn't low pass my sub at 100hz with a 6db sloppe... you know
just play with the setting till you doesn't pick up midbass lines. The sound will be cleaner, you 'll see
BamBam28
BamBam28
AL
masterbassin
