amp settings
Bobby322
My friend borrowed my amp and I got it back and the settings were all over the place. I was listening to some music and it sounds like I'm not hitting the lows good at all. What setting controls this? Also, I turned the bass eq like pretty far up and its ****ing loud. But as I turn the volume up my subs start sounding funky. Basically, what should all my settings be at? System setup is in my sig
start with these settings and then tweak to your liking
lp = 80hz
ssf = 25 hz
bass eq = 0db
phase = 0
level/gain = to what your hu's rca voltage is (4volts idk?)
start with these settings and then tweak to your likinglp = 80hz
ssf = 25 hz
bass eq = 0db
phase = 0
why would u do that.. my rca voltage is 5v but my gain is at about 2.5
if its not playing the low notes, the subsonic filter is up too high, that should be set to 15hz.
Gain should never be over 3/4, i dont even go past half. Low pass filter... 50-80hz usually, depending on how low you like your components to get.
Bobby322
Bobby322
TX
macq32
BP1Fanatic
BP1Fanatic
