amp safe off stock
Smac
I need $
Ok. Right now i got 2 10w7s sittin in my room with nothing to power em. So i need an amp that will put out decsent power at 1.5 ohm since 10w7s are 3 ohm svc for some retarded reason. But heres the thing, I want to do this off stock electrical. I know the subwoofers are rated at 500, but i have no problem sending them 400 or 450 each if i have too, specially since the difference is inaudable. This will be off a 105 amp alt and 12v battery. So please recommend me an amp that is no more than 300-350 bucks.
yes use 2 guage if u want 2 upgrade in the future or 0/1
look at it this way, if u think ur probably gonna upgrade later, wouldnt it b easier n cheaper 2 run the 2guage now, instead of runnin 4guage or 8guage now then goin through the process of rippin ur car apart and upgrading to the 2guage later on
if the wires already there its basically plug n play //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
and if u use a thicker wire than u can fit in the amp, jus take a knife and start cuttin away at the outside of the bare wire till it gets sized then u can solder it n stick it in or u can jus buy a terminal that will turn the 2guage into 4guage or watever, or get a distro block that will take that 2guage n make it in to 2 4 guage outputs
Run 1/0 now...it shouldn't be that much more expensive than 2. You can check out http://www.knukonceptz.com for wiring/accesories. You should also buy some extra 1/0 and do the Big 3 under the hood, if you plan to not upgrade the batt or alt. The Big 3 should only require about an extra 5-10ft total, depending on the car.
Smac
I need $
Smac
Iowa
BassAddictJ
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
