amp randomly turning on and off
you're daisy chaining it? And you still have the US amp or did it blow up like it should? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
yes im daisy chaning it. and yes i still have the US amp and still running strong //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
*poof* not anymore.
But like others said already, check all the wiring. Speaker wires maybe loose. Check your RCA connections also. Just make sure everything is tightly connected first. And i say run your ground to your batt just make sure. I doubt if you will do that though lol.
*poof* not anymore.
doubt ill do what? run the ground to the battery? **** right i wont, lol. i have a nice ground in the trunk. but im thinking its a loose fuse or something wrong with the remote wire, but last time i checked real quick, the remote wire was good, but i'm taking everything out of the trunk today and making sure.
you poor bastard, you can't even afford ground wire //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
this is what should be done
i dont have a DMM
what are you talking about? i have ground wire, i dont see a point in running the ground to the battery when i have a good ground in the trunk
you can determine if you're getting the right voltage to the amp...And yes, it is much easier on you
ill probably go to homedepot after school and try and pick one up if its less than 40 dollars. employer messed up my paycheck so i gotta wait and go talk to the guy tomorow about it before i have some money in my hands =/
blimblam
blimblam
new orleans
redeldog1
