amp rack ( stacking ) ?
big scott
blazin low, and loud
hi guys,
im going to start ordering some amps. ill have 4 or 5 not sure yet. it will be at least 4 . just not sure if im going with an extra set of 6x9 yet.
i have my amps flat, and i plane on stacking them on top of each other. what i need to know is how much space should i set from one another ? from top of one to the bottom of the other.
if i do 5 amps not sure how ill mount it.
but my plan is to mount 2 ppi 1800 ( one on top the other ) and 2 smaller ppi amp and they to will be stacked.
so when all said and done ill have 2 stacks side by side.
i just dont want to stack them to close for cooling and looks of course .
also should i put a few computer fans on them to help keep them cool ?
if so 1 one each stack ? or 1 per amp?
I used 4 threaded rods for the correct height of the nuts to use for the amp base. To hide the threads of the rod I use custom cut brass tubing in between each nut corresponding to the specific height I was using.
big scott
big scott
edgewood, md
yogegoy
AJ (ACE)
    Jun 28, 2026
