Amp question!!!
  • 4
sexyswede
If i hook up 4 coaxial speakers to a 2 channel amp,
and run two speakers off of each channel,
then i'd get a 2 ohm load on each channel, correct?
Do the "channels" have anything to do with the left/right imaging you get in music? or is it just two outputs of power?
Cause i want to run my front speakers and my back speakers off of a 2 channel amp. I can do this, right?
What are a good pair of full range speakers for my back seats anyways?
and i was thinking of this amp by JBL...
Its 90Wx2 at 2 ohms btw
I want to keep the amp and back speaker cost under 200 btw
channels = L and R. they also let the power flow to your speakers from the amp
well then that *****, i guess.
cause then i'd have to have two completely different speakers feeding off of the same line of power. and that i assume is not good?
well if you hook up the 2 left speakers to the left chan, and 2 right speakers to right chan, you'll get proper imaging in your sound. just wire the 2 L speakers together, and the two R speakers, and attach them
Originally posted by more_spl well if you hook up the 2 left speakers to the left chan, and 2 right speakers to right chan, you'll get proper imaging in your sound. just wire the 2 L speakers together, and the two R speakers, and attach them
thats what i thought, but wouldn't two completely different speakers drawing off of the same source be bad?
wouldn't one try o take precedence over the other?
well are you supposed to run 4 amps to 4 speakers? nope. the L and R channels from the amp will sort it out before it hits the speaker
nope... shouldnt...
only thing is, you will lose your front/back fading..
as your amp will now recognize both right speakers as teh right side, as 1 speaker, in essence, and both left the same way...
It depends on the impedence of the speakers. And the capabilties of the amp pushing them. As for one taking precedence over the other. The amp doesn't know how many speakers are connected to it. Be it 1, 2 , or a billion. As long as the impedence is right. It doesn't matter. IF you turn on the lights in two rooms of your house, Does the first room go out because you turned the second one on ? Same thing. The power in your house is from a single source that everything shares. Same way with amplifiers. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
668
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
sexyswede
sexyswede
Encinitas, CA
ramos
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
