Amp question
This should help found it on this website about sony ampshttp://www.teamrocs.com/reviews/amplifiers/XM2252HX.htm
These bicolor LED's will go from green to amber to indicate a problem with your setup. They are labeled "Over Current" (you are driving too low of an impedance load or the speaker leads are shorted directly), "Offset" (the amp is generating DC current - you probably have a ground loop somewhere, check the amp mounting screws for grounding, and your power / ground connections), and "Thermal" (overheating).//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
I'll go out and check the mounting screws now and see if that helps.
Thanks to all whose replied. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Ok i removed themounting screws from the back of the seat and placed the amp on a board and it seems to be working better, cant test too loud here (thats when it happened at higher volumes) my neighbors will freak when there pictures fall off the wall as usual...
Thansk again to everyone who helped. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Colt9699
Rockstar
Colt9699
Erie Pa
Colt9699
michigan born
    May 14, 2026
michigan born
    May 14, 2026
