amp problems
MOFOMAN
Michigan
the other day i went to get inside my car (it was raining) an when i got in my subs started making this poping sound so i turned my car off went to check everything the amp smelled like it was burning up so i unplugged everything an took it inside for the night this mourning i hooked it back up an it was working fine drove around the block an it cut out again with more burning smell i have no idea what could cause it to act like this
planet audio ap3000d its not really mounted it just layed in the back of my van 2 alpine type e's in bandpass box running at 2ohms
Sounding like that amp is pretty much done.... Be sure to mount the amp you replace it with somewhere solidly where it can not move around & won't overheat on you, I would also check your ground connection point(s) because inadequate grounding can really shorten an amps life, especially budget amps...
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
243
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
What amp/make and model and what sub/make and model. What HU being used?
195
334
MOFOMAN
MOFOMAN
Michigan
MOFOMAN
Dan Medina
    Jun 17, 2024
    Jun 15, 2024
