Amp power wire fuse question.
s0nl33t
Canada
I have a 5 channel amplifier that's 3700 watt, what size fuse would I need on the power wire? The amp itself has 2 40amp fuses. I would assume a 100 amp fuse would suffice with 4 guage wiring? And will a single battery power this unit?
Thanks.
A true 3700 watts will pull more than 80 amps.
What amp and what is the RMS rating?
100 amp fuse and 4 gauge will be good for that amp based on its fusing.
Cheap 4 gauge CCA wire is rated at 60 amps for a 20' run.
Quality 4 gauge CCA is rated 100 amps  for a 20' run
Quality 4 gauge OFC is rated 150 amps for a 20' run.
An amp with two 40 amp fuses will have no problem being ran off a single battery.
The kit I was looking at is by Surge, the F-4. 18ft. 4 gauge. Perfect, I didn't think I'd have an issue but I wanted to make sure.
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
s0nl33t
s0nl33t
Canada
s0nl33t
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
