85Caprice4d
I have had a shitty boss amp and 10' jl audio sub in my caprice since i got it. Its not the best, and its hooked to a cd player with no functioniong cd capabilities. Anyways, back in the day my amp was not secured, and when I would take corners it would fly around. This caused the power wire to come loose from the U ring which connected it to the amp. I didnt have another U ring that would work, so I tried to unclamp this one, and i put the power wire back in, and re-clamped that bish. I also duct taped my amp in place for lack of motivation to properly secure my shity temporary 'poundage' if you can even call it that.
So over time, I found out that the wire had to be in at certain angles for it to get power to the amp. After several trials, I found a good position and taped it there. Tonight i got bored and sick of the amp cutting in and out, so I went to cut an o ring into a u ring. That worked fine. I hooked it all up, no problems it played. Then I wanted to get a little more slack on my power cable because it was pretty taught. I pulled some of the excess from the engine compartment, all the way to the trunk. I electrical tape on it, and thought I would be set...NO GO
Light on the amp wont go on.
I tried taking power wire out of ring, putting the bare wire on the screw...
re doing my ground, re connecting power to battery, remote wire....
fuse looks good to me?
I dont know what to do and I really dont have money for a new amp what with the holidays rolling in with great haste...
Anyone can advise me on what to do?
(no baggin on my sh it setup - i know it sucks, it gives me very little bass, but this is a daily driver, and for now it works)
thanks for any help, ideas, questions, anything -
LD
LD
