amp power question
couldnt I run the 4ohm subs in parallel so that its in 2 ohms now?
Each sub can be ran at 2 ohms, but when wired together you get a 1 ohm load or a 4 ohm load.
The difference between the loads is the amp will 'see' a different amount of resistance, and will put out different power dynamics at different impedances. 1 ohm would be less than 4 ohms, so the amp can put more power out since there is less resistance on the circuit.
im sorry that power acoustik is stable at 1 ohm. so with the amp being stable a 1 ohm is this still a good combination with the alpines?
blackhawk911
blackhawk911
CT
SUB_URBAN
