amp placement?
R0ID_RAGE
1. where is the best place to put my speaker amp? 4 door sedan...
I was thinking the easiest would be in the trunk next to my sub amp.
I'll have 4awg power wire running all the way to the trunk, split by a distro block into 2 4awg wires. 1 going to my sub amp, the other to my speaker amp. How long is too long for the power wire after it goes through a dist. block?
2. also, should I ground the distro block (SS powerplant) or just ground each of the amps?
Logically, I would place it in close proximity to your power wire run or battery. Amp placement is becomes more important when using multiple power hungry subwoofer amplifiers.
...so in the trunk next to my other amp would be better than under my seat?
R0ID_RAGE
R0ID_RAGE
FLORIDA
DBDRAGGUY
