amp overheating
Scott37
Have an older mtx amp and it is getting so hot it shuts off in the first 20 minutes of powering up.... I been out of this for a while but don't remember my other systems doing that do I maybe just need to put a fan on it. ..
Any insight appreciated
Its a mtx thunder series amp will post which one when I get home but yea it's mounted on the box flush to the carpet. ... its a 4/2 channel amp bridged only running at 4 ohms and the bottom says it can be ran down to 1
If it is clipping it will heat up quickly. Try notching the gain back a little bit and see if that helps. Also if tour power and ground have bad connections it can cause extra heat also
I have an amp that runs hot normally, Cadence 5000.5, I had a piece of 1"x1" that I cut an inch less than the diameter of the amp, (2 pieces) then used velcro to attach the 1x to the amp and then used some on the bottom of the 1x so it wouldn't slide on the carpet. May sound crude but it works to allow air circulation all the way around. Also I installed a few fans to help.
Turned gain back still no good going to raise amp so it's not directly on the box. ..It's been sitting in the garage for a couple years lol it might just be time for a better one
most all of my old school amps run hot - but id bet yours is having some internal components start to go bad over time - diode resistor bla bla ext have a usefull life span on car audio parts... me personaly i would swap out for something newer and cheap since you only need 250w
Scott37
Scott37
Baltimore
brian84corvette
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
