When you bridge an amplifier and connect 4ohm load, then the channels are running at 2ohm internally. That alone puts more stress on the amplifier. The GRA-802 a cheap _compact_ class A/B amplifier that's primarily meant for powering full range 4ohm loads. That you can power a 2ohm load with such an amplifier is merely a theoretical possibility. I always had thermal stability issues with an A/B/ channel running at 2ohms. There is nothing wrong with using bridged channels for subwoofer duty if the amplifier is fit for it, but I'd recommend a Class D amplifier in that role.. with some exceptions (For example, Boston Acoustics 2-channel GT-Class amplifiers, which are Class A/B, are supposed to be fit for subwoofer duty bridged).
